ABS in dishwasher?
- eekee
- Main keyboard: A slim Logitech; nice action but getting creaky
- Main mouse: SpeedLink SL-630001-BK - lovely feel
- Favorite switch: No rebound; click; other TBA
Just checking, are ABS keycaps likely to survive a run through the dishwasher? It's not a classic keyboard, in fact it's one I'm a little bit annoyed with, but would just be useful right now.
- Wodan
- ISO Advocate
- Main keyboard: Intense Rotation!!!
- Main mouse: Logitech G903
- Favorite switch: ALL OF THEM
I've run dozens of Cherry Classic Beige ABS Doubleshots and G80/Model M Keyboard cases through a dish washer and haven't had any issues with them!
I did however see rare issues with darker ABS like White-on-Black or Skidata keycaps.
My dish washer has a 45°C program which is a borderline temperature for ABS caps. Anything higher than 50°C is really not recommended at all and at 45°C you might be on the safe side for many types of ABS. Be aware there are tons of different kinds of ABS - just compare a bag of legit LEGOs with a bag of China fakes.
The best way to go is ultrasonic cleaning.
- eekee
Thanks Wodan. They are indeed white on black in appearance if not brand. My dishwasher doesn't have any temperature indications and it's plumbed into the hot water line, so I'd best not try it.
- eekee
THat makes sense. They're not thin but they are full-height, and the stem is part of the cap. It would be bad if that warps.
- Blaise170
- ALPS キーボード
- Main mouse: Logitech G502
- DT Pro Member: 0129
- TuxKey
- LLAP
- Main keyboard: Leopold FC660C, Leopold FC660M mx-clears
- Main mouse: Apple Magic Trackpad, ducky Secret (PBT mouse)
- Favorite switch: Cherry MX-clear, Topre 45gr/55gr
- DT Pro Member: 0137
ever since i watched Wodan clean using his ultrasone cleaner i knew one day i would get one..
as soon as i have the space for it.. sucks living in a small apartment..
here's the vid ...
https://youtu.be/l1wl9Vm3zdM
hahaha
here's the vid ...
hahaha
- DT Pro Member: 0011
Ultrasonic is probably best. I think denture cleaning tabs contain abrasives and hydrogen peroxide.
Anyway, the best cleaning tip: Use a washing bag! That way you can wash, rinse and dry all keys as one unit.
- eekee
Before posting this, I read a thread describing an ultrasonic cleaner not working well on plastic, taking far longer than it did on metal. In the end, one of the guys found 48 hours with some denture tabs worked much better. There's that, and my lack of space, and my experience of PBS caps coming up fine in the dishwasher which all persuades me not to buy one.
I've currently got the ABS caps in a sealed container with ordinary dish-washing liquid, agitated at intervals. I'll post how they come out later.
- mark201200
I've tried cleaning caps with Oxi Clean. Works wonders, just soak them for a couple of hours.
