We should make a full-size keyboard kit.
- abrahamstechnology
- DT Pro Member: 0212
At a time when a full-size Chinese "gaming" mechanical keyboard can be shipped to your door, for under $40, I don't see why we can't have a barebones full-size keyboard kit for at most, the same price. No RGB, edgy gamer keycaps, etc, just a simple PCB, mounting plate, and plastic case. Kind of like a modern AT101.
I know I'm relatively new to mechanical keyboards, but I'd really love to see this happen. I for one would certainly buy them on a regular basis. It would be great if we contacted one of those Chinese manufacturers to make this happen. What do you think?
- Quartz64
- Main keyboard: Kinesis Contoured (Kailh Box Black, Koala)
- Main mouse: Elecom Huge
- Favorite switch: Durock Koala
- DT Pro Member: 0253
I don't think that it's possible even with group buy discount. Gateron switches: $20, stabilizers (that don't suck): $10, blank PBT keycaps: $20, total $50, not counting PCB and case.
- matt3o
- -[°_°]-
- Main keyboard: WhiteFox
- Main mouse: Anywhere MX
- DT Pro Member: 0030
Chinese "gaming" mechanical keyboard kits? Can I see some of these?!
- Wodan
- ISO Advocate
- Main keyboard: Intense Rotation!!!
- Main mouse: Logitech G903
- Favorite switch: ALL OF THEM
You mean a G80-3000 + plate?abrahamstechnology wrote: At a time when a full-size Chinese "gaming" mechanical keyboard can be shipped to your door, for under $40, I don't see why we can't have a barebones full-size keyboard kit for at most, the same price. No RGB, edgy gamer keycaps, etc, just a simple PCB, mounting plate, and plastic case. Kind of like a modern AT101.
There's been custom G80-3000 PCBs before and even an ongoing project.
There will be a fullsize TX Keyboards kit soon.
Also there was the LZ-Stan
- LessthanZero
- Main keyboard: MicroSwitch SD
- Main mouse: Logitech trackball
- Favorite switch: white Alps
I know what you mean though it does seem there are very few full size keyboard PCBs. I have found tons of 60 percent or smaller and a few tenkey less but only the one full size which is this one,
http://www.gonskeyboardworks.com/pcbs-a ... ver15.html
I couldn't find anything else in stock and if you want alps switches good luck, I guess you gotta make your own. But getting a PCB etched isn't that expensive I was going to make a board based off the Sun type 3 layout it is going to be for Alps switches, but if your interested I can make one for MX style as well. I had already planned on making a Microswitch SD switch version as well.
I'd gladly pay $30-40 for a normal, non- "gamerey" case and PCB alone. Just a simple plastic case, no-frills PCB and metal mounting plate.
- Myoth
- Main keyboard: IDB60
- Main mouse: EC1-A
- Favorite switch: Cap BS
a Google search guys ...
a Google search ...
https://fr.aliexpress.com/item/-/32829787493.html
EDIT : damn that's cheap :O
https://m.fr.aliexpress.com/item/329073 ... form=msite
a Google search ...
- Wodan
- ISO Advocate
But your main keyboard is supposed to be a Wyse WY-60.
That's pretty much a G80 with a plate and a bit weird layout
Afaik there are Wyse models that have more standard layouts.
- Wodan
- ISO Advocate
- matt3o
- -[°_°]-
okay the question is. why buy such low quality mechanical keyboard? better buy a good rubberdome than a shitty mechanical
Unfortunately, the first one is no longer available.Myoth wrote: a Google search guys ...
a Google search ...
As for the second one, nice deal, although I'm personally not a fan of the exposed switch design.
- Blaise170
- ALPS キーボード
- Main mouse: Logitech G502
- DT Pro Member: 0129
If I'm going to buy any more modern keyboards, they will surely be exactly what I want. The cheap Chinese boards have gotten so cheap over the years that you'd never be able to compete. I got a TKL with full LED lighting shipped direct to my door for around $25 a few years ago. Things are even cheaper now. It was different back then because customs were mostly out of this world on pricing (easily $400+ in many cases) and there wasn't much in the lower end that people could get, but there's too many manufacturers in this space now. If you are wanting to aim for a particular market, you'd almost definitely want to aim for the middle end ($100-200 range) as this is where most boards are priced. Hell, even the Keycool TKL on Massdrop right now is only $60 and it comes with PBT caps if I recall. You'd really need to have a radical idea to really get off the ground on a project like this.
That's the thing, I'd want something the LEAST radical as possible. Just a simple, normal, full-size, AT101-like chassis.Blaise170 wrote: If I'm going to buy any more modern keyboards, they will surely be exactly what I want. The cheap Chinese boards have gotten so cheap over the years that you'd never be able to compete. I got a TKL with full LED lighting shipped direct to my door for around $25 a few years ago. Things are even cheaper now. It was different back then because customs were mostly out of this world on pricing (easily $400+ in many cases) and there wasn't much in the lower end that people could get, but there's too many manufacturers in this space now. If you are wanting to aim for a particular market, you'd almost definitely want to aim for the middle end ($100-200 range) as this is where most boards are priced. Hell, even the Keycool TKL on Massdrop right now is only $60 and it comes with PBT caps if I recall. You'd really need to have a radical idea to really get off the ground on a project like this.
- matt3o
- -[°_°]-
I bought some mid tiers in the past (not even the super cheap ones) and the difference with the $100+ is pretty clear
- vvp
- Main keyboard: Katy/K84CS
- Favorite switch: Cherry MX
Well, I have 2 metal plates for ansi 105 key keyboards. They are intended for iron recycling. If somebody is in Slovakia then he can pick them up for free (PM me).
Though I do not understand why one would build a standard keyboard. It's just easier to buy it.
- Blaise170
- ALPS キーボード
Simple, no-frills keyboard for ¥169 ($24.78).
https://detail.tmall.com/item.htm?spm=a ... 4500451001
Not for me, I love making things. Besides, then I would just buy a Model M.
LED backlighting and ugly gamer font, not really what I had in mind.Blaise170 wrote: Simple, no-frills keyboard for ¥169 ($24.78).
- Blaise170
- ALPS キーボード
The ¥169 option has no backlighting and for the money you saved you can replace the keycaps.
- Myoth
- Main mouse: EC1-A
no frills ? "RGB", floating key design and chrome finish ?Blaise170 wrote: Simple, no-frills keyboard for ¥169 ($24.78).
I don't think that's frill-less
All I'd want is a simple chassis, simple PCB, and plate.
LeslieAnn
- Main keyboard: KBT Race S L.E.
- Main mouse: Logitech G700
- Favorite switch: Ergo Clear
These cheap keyboards are what is known as white label keyboards.
All the engineering has already been done, the parts are engineered down to the penny and are known to work together. They are kind of like those promotional pens companies have with their logo on them, you pick a style, a color and then they stamp your logo on it, it's the same thing here.
Changing anything, and I do mean anything, will significantly up the price because they need to make sure it all works with not just their product but also their assembly line which is geared towards large runs of generic boards. More than that, these keyboards are engineered to be purchased by the thousands, not 100 or 200. Any change at all for such a small run will incur significant fees as a result.
- vvp
I understand that. My point is that if you enjoy building keyboards than it makes more sense to build something interesting, something you cannot easily buy. E.g. a custom topre board: workshop-f7/designing-a-custom-topre-board-t11734.html
LeslieAnn has a good point about price too. I think that what you want does not make much sense.
Hak Foo
- Main keyboard: Omnikey 102 Blackheart
- Favorite switch: White Alps
- DT Pro Member: 0174
I think that a lot of the novelty comes these days from switches and caps. There are already affordable kits for many of the TKL and smaller sizes. But for 100% and beyond, options are skimpy.
If you carefully collected 104 blue ALPS switches, your best choice now is to desolder an Omnikey, AEKII or AT101W and rebuild it. It's likely similar on the MX side. I know there are a few drop in kits like the Leeku 3000, but that still involves buying a unit to scrap for the case.
The white-label boards are already resolved designs, more or less bullet-proof, so all you'd be saying is "sell us the same board you sold to Rosewill or CoolerMaster, but don't drop switches or caps on it as it slides through the assembly process.
