Hello, are there any projects for a working model f xt pcb? I'm going to use it on xt and bigfoot keyboards. I think that a new pcb plus an xwhatsit controller would be a nice combo.
Thanks for any suggestions.
ibm model f xt pcb
JBert
- DT Pro Member: 0049
If you mean making your own you could read the XTant and Model MF project threads:
workshop-f7/bringing-the-ibm-pc-xt-into ... t3047.html
workshop-f7/remodeling-the-model-m-t13796.html
xueyao
- Main keyboard: IBM Model F122 XT Beamspring 3727
The stock XT controller can be easily adapted to USB. Why go through the trouble of replacing the PCB and controller?
Sent from my SM-G965F using Tapatalk
gianni
What do you mean with adapted? Do you mean an external soarer's converter? It surely works with the xt, but the bigfoot, I'm not sure that there's such thing. Or probably it works with some bigfoots, while it doesn't with others.
gianni
Thanks, for the links, I'll read and then ask the project leaders if the have some pcbs already available.JBert wrote: If you mean making your own you could read the XTant and Model MF project threads:
- DMA
- Main keyboard: T420
- Main mouse: Trackpoint
- Favorite switch: beamspring
- DT Pro Member: NaN
cut traces on existing PCB separating matrix from controller, solder the controller to matrix. CommonSense will work, with xwhatsit YMMV.
xueyao
Bigfoot has been successfully converted with a teensy. Can't find the thread now but it's fully documented and seems quite doable.gianni wrote:What do you mean with adapted? Do you mean an external soarer's converter? It surely works with the xt, but the bigfoot, I'm not sure that there's such thing. Or probably it works with some bigfoots, while it doesn't with others.
Yup. Much, much less effort, expense and destruction to convert with a Teensy inside than swap out the original electronics.
