This is John from Velocifire. Currently we have a 20% off discount code for our TKL wireless keyboard TKL01
It's Amazon's choice for "wirless mechanical keyboard"
Code for velocifiretech.com and Amazon:E9HEO4XR
Down from $39.99 to $31.99, Valid till Sep 23.
Link: http://www.velocifiretech.com/product/v ... -wireless/
Specifications:
Polling Rate: 1000 Hz
Switches: Outemu Brown Switch
Keycaps: ABS double-shot
Connector Type: USB 2.0 (Wireless 2.4 GHz) USB 2.0(Wireless 2.4 GHz)
Rollover: 87-key
Battery Type/Size: Build-in Lithium Battery/200 mAh
Wireless Range: 26 feet/8 meters
Backlit: N/A
Compatibility: Windows 2000/XP/Vista/ 7/8/10/ LINUX
Warranty: 1 year
Cable Length: 50 cm
Product Weight 2.7 pounds
Product Dimensions: 14.5 x 7.7 x 1 in
EDIT: WE GOT A 104 key wireless mech board on Dealnews, cutting $49.99 to $39.99 with Coupon code "N9QRRARA" at
https://www.dealnews.com/Velocifire-Wir ... 75673.html
A little bit about us:
1. We make entry-level mech boards for work and study, coz we think mech board are much better than membrane boards. Even we are not gaming, we should have one. But many membrane keyboard users may find mech boards over $100 is way too expensive when they just spent $15 on a membrane one. So we take away RGB,and make simple ones with relatively quiet switch. If you search velocifire VM01 on youtube, you can see many video about it back in 2016, saying it's the 1st mech board at $35 or so.
2. We further made this TKL01 wireless for work. Although it has no backlit, it's still really a good choice with such discount.
3. Our team have been using every of our keyboards, and love the products a lot ourselves. We hope it will be a best choice before anyone would love to spend over $100 on a really high end one, with RGB, or more features.
Feel free to ask if you have any questions.
