Hey Guys,
Looking for some new Goodies to Buy :
*EnjoyPBT Hiragana PBT Sushi
*PCB-Mounted Black or Yellow Gateron Switches 50pcs
*some Nice PBT Mods or a Blank Keycap Set (Something that fits to my beloved triumph adler Keycaps)
Thank you for your time
EnjoyPBT Hiragana / PBT mods or Blank Set
- Jimmy54669
- Main keyboard: GK61 / DX60 case / Quefrency left as gamepad
- Main mouse: Logitech G305
- Favorite switch: Navy Box / Gateron Ink
- abrahamstechnology
- DT Pro Member: 0212
Just a warning, the retooled BOX switches still crack keycaps. Not as severe but they still do.
- Jimmy54669
Thanks for the warning, but i cant live without my Navy Box, so i have to wait and use non expensive Keycaps in the Meantime.
I recommend you can use pliers to remove the nubs. It sometimes makes the keycaps too loose, but you can use a bit of plastic bag to remedy that.Jimmy54669 wrote: ↑Thanks for the warning, but i cant live without my Navy Box, so i have to wait and use non expensive Keycaps in the Meantime.
- Jimmy54669
if I have the time and want to use ABS Keycaps i will do this, atm iam using Triumph Adler pbt keycaps they hold up pretty good, cheap pbt caps i had on them cracked within one week
