[WTB] Plastic Frame for Model M 122
ConiKost
03 Mar 2019, 13:57
Unfortunately, my plastic frame broke with multiple cracks, so I am searching replacement.
-> https://imgur.com/a/YRlTNX9
What I noticed, the plastic frame of my IBM 1390584 is not the same, as in my newer IBM 1397003, which has the smaller and newer case. Does anyone have a replacement for me?
elecplus
03 Mar 2019, 14:10
Where are you located?
ConiKost
03 Mar 2019, 15:29
elecplus wrote: 03 Mar 2019, 14:10 Where are you located?
Germany
Return to “Want to buy”
