Topre 2u modifiers housings and Novatouch spacebar stabs and wire
phinix
04 May 2019, 02:10
I'm looking for 3x Topre 2u modifiers housings. Either from Realforce or Novatouch.
Also after Novatouch spacebar stabs and wire.
I know this is a long shot, but hey...
AdrianMan
06 May 2019, 07:43
Heya, KBDFans 2u sliders are working great + lube, so that's an excellent replacement and you can use them with the stock drilled housings.
As for the 6u , that's tricky :) you can try the Costar/Cherry plate mount mod.
I have both some KBDFans 2u's and also foe spacebar cherry plate+costar including the 6u wires if you wanna go that route :)
phinix
07 May 2019, 00:18
AdrianMan wrote: 06 May 2019, 07:43 Heya, KBDFans 2u sliders are working great + lube, so that's an excellent replacement and you can use them with the stock drilled housings.
Hey. Don't need sliders, I need 2u housings.
AdrianMan
07 May 2019, 06:04
Oh I see. Don't you have the 2u topre ones that you can drill and use ?
phinix
07 May 2019, 20:06
nope:(
AdrianMan
09 May 2019, 10:13
https://www.reddit.com/r/mechmarket/com ... caps_alps/
this guy sells some realforce housings and seems to have the 2u's as well. Send him a message :)
phinix
12 May 2019, 23:34
Thanks, I think I found source for housings, but still gonna need speacebar stabs.
Return to “Want to buy”
