my pingmaster board interferes with bluetooth, for example if my apple magic trackpad is within 6 inches of the board the cursor lags and skips badly and if you hold the trackpad directly over the keyboard it loses bluetooth connection entirely.
is there any reason for concern or easy fix?
IBM pingmaster and bluetooth interference
cloudhax
thanks, if I get the guts to try opening this thing and poking around I'll give that a try. Should I be worried this thing is frying my brain? Do I need a tinfoil hat? ThanksLbibass wrote: 28 May 2019, 02:02 You could try putting an EMI shield on top of the controller. Some thin foil or something could work. But try and prevent it from shorting out the components!
- Wazrach
- Main mouse: Razer Viper 8KHz/ Viper Mini
I love the smell of the Pingmaster. It just hits you when you take it out of the antistatic bag for the first time.cloudhax wrote: 02 Jun 2019, 15:18 Also have you ever stuck your face down in a pingmaster and taken a good whiff? Smells of pure burning plastic. That's gotta be toxic right? (smells fantastic btw)
