[IC] DSA Red Planet
Freeaboo
23 Oct 2019, 03:31
Take to the stars with DSA Red Planet, my new keyset!
[Ares Module](https://imgur.com/a/4DAWzyq) - Base kit - $100
[Surface Module](https://imgur.com/a/fEGC3Ll) - 40%/Ortho kit - $40
[Booster Module](https://imgur.com/a/4DYSTni) - Numpad kit - $35
[Rover Module](https://imgur.com/a/bBm0LMB) - Spacebar kit - $15
Pricing will depend on how much interest the community shows. Current prices are estimates.
Sorry if this looks messy. I copy-pasted this from my Reddit post, and I'm not too familiar with hyperlinking on this site. Cheers!
23 Oct 2019, 03:38
The base kit is missing an alpha key: you have a short left Shift (for ISO keyboards), but not the 1U alpha key that should go between it and Z.
Also, the R3 key to accompany the vertical Enter should be \|, not #~.
Also also, you have the 1.5U R2 \| key twice (and with the same color).
Lbibass
23 Oct 2019, 04:09
depletedvespene wrote: 23 Oct 2019, 03:38
No, not really.
23 Oct 2019, 04:15
Lbibass wrote: 23 Oct 2019, 04:09
depletedvespene wrote: 23 Oct 2019, 03:38 Also, the R3 key to accompany the vertical Enter should be \|, not #~.
No, not really.
Yeah, it totally is and, like, stuff.
23 Oct 2019, 09:59
That depends on which English UK layout you cater to. The keys are are different on US-ISO, and on UK-ISO layouts on PC and Macintosh.
BTW, there is a horizontal line instead of wavy tilde symbol ~ in the render.
23 Oct 2019, 15:39
Findecanor wrote: 23 Oct 2019, 09:59 That depends on which English UK layout you cater to. The keys are are different on US-ISO, and on UK-ISO layouts on PC and Macintosh.
I am quite aware of that.
Findecanor wrote: 23 Oct 2019, 09:59 BTW, there is a horizontal line instead of wavy tilde symbol ~ in the render.
Indeed. Last night, I dismissed that thinking it was just a poorly-rendered tilde (check out the "backquote" in the same key), but looking at it again, it looks more like an en dash than a tilde.
Freeaboo
26 Oct 2019, 04:09
depletedvespene wrote: 23 Oct 2019, 03:38 The base kit is missing an alpha key: you have a short left Shift (for ISO keyboards), but not the 1U alpha key that should go between it and Z.
I will take note of this. I am going to move the ISO keys to a separate kit, which will also include NorDeUK caps.
