Any help getting an XT keyboard to work with a Pro-Micro?
- Jesseg
- Main keyboard: AEK1 - SKCM Salmon
- Main mouse: m720
- Favorite switch: Capacative buckling spring, Linear space invader
I picked up this old XT Keyboard with MX blacks, and a super heavy case, I really like this board and I’m trying to get it to work but it doesn’t want to play. Anyone able to help me out?
- DT Pro Member: 0011
Both the Clock and Data lines should have 4.7K pull-up resistors to +5V.
Which firmware?
If you're using TMK, by default Pin "2"=PD1=Clock, and Pin "3"=PD0=Data unless you modify tmk_keyboard/converter/xt_usb/config.h (but I see no reason to).
You have connected pins "3" and "4" in the first image and just 3 in the second.
Which firmware?
