Xwhatsit controller for IBM Model F XT
Because you're gonna snap off the original? It's non-detachable. That's the only reason the XT isn't compatible.
wiki/IBM_Personal_Computer_keyboard
Kashtan
- Main keyboard: BENQ A800
- Main mouse: Logitech Pro Wireless
Is it possible any chance to replace a defective part? Any controller?Muirium wrote: 16 Dec 2019, 23:24 Because you're gonna snap off the original? It's non-detachable. That's the only reason the XT isn't compatible.
Or is it just only a piece of junk for $ 200?
- abrahamstechnology
- DT Pro Member: 0212
What about it doesn't work?
Kashtan
I don’t know what exactly does not work there. I changed three converters.
The keyboard worked for 8 hours, and then stopped without any warning.
The only thing that’s wrong is that three switches are broken (my bad).
It could be bad caps.
The first thing to blame on old electronics not working is often electrolytic caps. Even worse since this is capacitive sensing in itself.
Kashtan
Checking of capacitors a possible only if complete remove it.abrahamstechnology wrote: 09 Jan 2020, 13:21 It could be bad caps.
Brocken switches can blocked work of electronic? Tonight i'm ordering five a pieces.
rhaberkorn
- Main keyboard: Robotron K7637
Hello Kashtan, did you end up replacing the capacitors?Kashtan wrote: 12 Jan 2020, 17:59 Checking of capacitors a possible only if complete remove it.
I'd be interested in which ones exactly you bought. I also plan on replacing my controller's capacitors.
Razerban
- Main keyboard: F122
- Favorite switch: IBM Beamsprings
Have a look at this post if you're still interested in changing the controller: viewtopic.php?p=474811#p474811rhaberkorn wrote: 15 Feb 2021, 22:36Hello Kashtan, did you end up replacing the capacitors?Kashtan wrote: 12 Jan 2020, 17:59 Checking of capacitors a possible only if complete remove it.
