I'm designing a PCB and although I'd like it to have more than 58 keys, I don't think that's gonna happen, at least with a Pro Micro (which I would rather use than spend like 6x as much on a Teensy, as well as redesign the work I've done in my schematic, which is attached). How can I wire a key matrix that will have all 58 keys? afaik I only have 8 lines available for both rows and columns, but mabye I'm missing something idk. The pins my guide said to use are PF0-PF7. Thanks!
Guide: https://github.com/ruiqimao/keyboard-pcb-guide
My schematic so far: https://imgur.com/a/03eTlz4
How do I make a 58-key matrix that works with a Pro Micro?
kelvinhall05
- Main mouse: MX Master 3
kelvinhall05
I want to use the Pro Micro as a daughter board. As I understood it, the schematic symbol that I used *was* a Pro Micro. Is it not?purdobol wrote: 09 Jan 2020, 22:55 I'm confused. You want to use Pro Micro as a daughter board or 32U4 chip integrated into pcb itself?
- purdobol
- Main keyboard: Custom
- Main mouse: MS WMO 1.1A
- Favorite switch: Marquardt Butterfly
No it is for the chip alone. Pro Micro has all the necessary stuff built in (like crystal, capacitors, resistors).
And has 18 pins available for use so up to 80 keys (10x8). So the only thing left is trace management and diodes.
kelvinhall05
OK. How would I do a schematic that uses a Pro Micro?purdobol wrote: 09 Jan 2020, 23:09 No it is for the chip alone. Pro Micro has all the necessary stuff built in (like crystal, capacitors, resistors).
- purdobol
Just ignore the "Schematic" part of the guide and follow the rest I guess.
When you get to the Routing paragraph, align the traces to correspond to the Pro Micro pinout.
wiki/Arduino_Pro_Micro.
Or maybe try handwiring method first. It'll be way easier, and it is great learning exercise.
kelvinhall05
OK, thanks. Can I make the matrix for 80 keys but have a few empty switch positions?purdobol wrote: 09 Jan 2020, 23:21 Just ignore the "Schematic" part of the guide and follow the rest I guess.
kelvinhall05
Yeah, not quite sure how to put it but imagine a 60% PCB with no switches where the Windows keys go. That's kind of what I'm thinking.
