Has anyone found an edge connector that works with the 5251 pcb? There are 3.96 mm pitch connectors out there but it's really hard to find one that works with the ~1.0 mm pcb thickness. I found this on ebay (https://www.ebay.ca/itm/5pc-Card-Edge-C ... 0887820549), wondering if anyone has tried these.
Thanks!
IBM 5251 Edge Connector
hcoopos
- Favorite switch: Buckling Springs
According to viewtopic.php?p=379215#p379215, that is what Orihalcon uses for his converters. Guess I'll order these
