Hello there,
I kinda like the coiled cables that come with some of the old Cherry boards.
I already found a guide about how to modify a 5pin DIN connector to PS/2. Is it possible to further modify the cable to
mini USB (for my 60%) - USB male (my PC)?
https://www.instructables.com/id/Old-Ke ... converter/
Possibility of modding a 5pin DIN connector to USB
- DT Pro Member: 0011
So.. in other words you want to build your own custom USB cable out of an old PS/2 cable?
Both USB and PS/2 use four wires + shield, so yes, that should work.
You should be able to find the connectors at electronic component retailers. Some custom keyboard shops also have parts or kits: custom USB cables is a thing.
I have also seen a thread or two on forums about how to make a straight cable into a coiled cable, if you'd want to go that route instead. And then there are ready-made coiled USB cables with paracord sleeving in a few shops. There is a whole lot out there to find.
hKing
- Main keyboard: 60% custom
- Main mouse: Glorious Model O
- Favorite switch: Cherry Vintage Black /w 85 cN
Thanks a lot for your input.
I don't want to completely build a new cable, I just want to rewire the existing old cable with new usb-connectors.
Do you know about some wiring diagrams? So that I can see which wire has to be attached to which usb-connector...
You should be able to find a wiring diagram in the connector's datasheet which should be available on the web shop where you would buy it. (If a shop does not provide datasheets for its components then it is a pretty crappy shop and should be avoided ...)hKing wrote: 07 Apr 2020, 15:59 Do you know about some wiring diagrams? So that I can see which wire has to be attached to which usb-connector...
Rauha
If I understand correctly, you do not want to modify 5pin DIN connector ( as the title says), but just use old keyboard cable with modern USB mini and USB A plugs?
For that, cut the DIN connectors from the cable. Then use use this digram. It shows USB A and USB mini pin outs. 5pin DIN cable has 5 cables for the 5 pins, so it should be easy.
hKing
Perfect picture, thanks!
The 5pin DIN connector has 5 wires.
Would it be easier to not use one wire (the thicker shielded black one) and just split the normal black one for the mini USB?
If not, can I just solder the normal black wire and the shielded black wire together to the corresponding pin outs?
I'd solder both black cables to the Standard A USB "GND"
I am not an electrician so maybe I am thinking too hard
