Anyone got a beam spring switch or an F hammer to sacrifice?
- bhtooefr
- Main keyboard: TEX Shinobi
- Main mouse: TrackPoint IV
- DT Pro Member: 0056
I'm wondering what material IBM used for the beam spring flyplates, or alternately for the Model F hammers.
Anyone got one to sacrifice, or otherwise know the material?
The patent says it's a high dielectric plastic, and that it can be injection molded, but that's it. So, what is it actually?
http://blog.makezine.com/2011/09/22/ide ... -plastics/ has some procedures that can be done to identify an unknown plastic. Obviously, there won't be any resin identifier on them.
ripster
- Main mouse: Mickey
You mean the barrels/case assembly for the keys? That's ABS on the IBM. The Unicomp is a bit less clear - that MAY be a mix. The hammers are interesting. I can use a Model F hammer to type on my iPad. I can't with the Model M hammer. Not sure the material though.
- bhtooefr
I mean the hammer itself. Barrels and case assembly aren't my concern.
The plastic case around the actual switch in the beam spring would also be nice to know about, although I suspect ABS would work fine for that.
- bhtooefr
Some theories that were being discussed were, if it's conductive, there may be metal particles. (However, it's supposed to be a dielectric. I'm guessing it's polycarbonate or PMMA.)
- RC-1140
- Main keyboard: Unicomp Terminal Emulator
- Main mouse: Razer Mamba
btw, to abuse this thread a little more: I would be glad if anybody had an additional Model M Hammer. My Model M2 has got a broken one. Probably a little easier to get by, compared to the capacitive variant.
- bhtooefr
Model M is far easier... although I forget if M and M2 are the same.
http://pckeyboard.com/page/Misc/PVPLASM
- RC-1140
Well, of course I know that Unicomp sells them, but I was wondering if anyone here in Germany or at least Europe had a spare one. Shipping from the US for only the Hammer would be an overkill.
- RC-1140
hm, thinking about the ergo ALPS board you still have put aside for me, this might be an option. I'll just have to wait for my pay. Probably the day after tomorrow you'll get a PM.
