SKCL compact PCB footprint
kelvinhall05
- Main mouse: MX Master 3
Hi guys, making a PCB for something and want to use some SKCL compacts. I am wondering if there is a PCB footprint for these, or if they just work with a normal SKCM/SKCL footprint. Thanks!
- ppCircle
- Main keyboard: Focus Fk-2002 HS Alps Blue / IBM 5140 Alps Brown
- Main mouse: Rival 300
- Favorite switch: Alps Blue / Alps Amber / Alps Brown / Alps N Green
Skcl compact uses same switchplate as normal size skcl/skcm switches so they have same footprint.kelvinhall05 wrote: 03 Jun 2020, 22:38 Hi guys, making a PCB for something and want to use some SKCL compacts. I am wondering if there is a PCB footprint for these, or if they just work with a normal SKCM/SKCL footprint. Thanks!
kelvinhall05
Good to know, thanks. Are they just half the height of a normal SKCL switch?ppCircle wrote: 04 Jun 2020, 02:12Skcl compact uses same switchplate as normal size skcl/skcm switches so they have same footprint.kelvinhall05 wrote: 03 Jun 2020, 22:38 Hi guys, making a PCB for something and want to use some SKCL compacts. I am wondering if there is a PCB footprint for these, or if they just work with a normal SKCM/SKCL footprint. Thanks!
- ppCircle
"The switch has a reduced front-to-back depth of around two-thirds of that of a full-sized switch" ~DT wikipediakelvinhall05 wrote: 04 Jun 2020, 02:13Good to know, thanks. Are they just half the height of a normal SKCL switch?ppCircle wrote: 04 Jun 2020, 02:12Skcl compact uses same switchplate as normal size skcl/skcm switches so they have same footprint.kelvinhall05 wrote: 03 Jun 2020, 22:38 Hi guys, making a PCB for something and want to use some SKCL compacts. I am wondering if there is a PCB footprint for these, or if they just work with a normal SKCM/SKCL footprint. Thanks!
kelvinhall05
I'm just making a modern PCB for my Sharp PA1000H with diodes and a built-in Pro Micro socket (well, two; one for the keyboard, one for the character lcd). Hoping it'll turn out well lol.andj00 wrote: 04 Jun 2020, 02:57excited to see what you build!kelvinhall05 wrote: 03 Jun 2020, 22:38 Hi guys, making a PCB for something and want to use some SKCL compacts. I am wondering if there is a PCB footprint for these, or if they just work with a normal SKCM/SKCL footprint. Thanks!![]()
Can QMK work without diodes? I am still not 100% sure if I will make my own PCB.
jkutianski
- Main keyboard: Compaq MX-11800
- Main mouse: Logitech MX Anywhere 2S
- Favorite switch: Cherry Brown (lubed)
Yes, but not expect NKRO on this without diodes.kelvinhall05 wrote: 04 Jun 2020, 03:01 Can QMK work without diodes? I am still not 100% sure if I will make my own PCB.
kelvinhall05
I expected that. Thanks!jkutianski wrote: 04 Jun 2020, 17:12Yes, but not expect NKRO on this without diodes.kelvinhall05 wrote: 04 Jun 2020, 03:01 Can QMK work without diodes? I am still not 100% sure if I will make my own PCB.
