First one is a wrench I needed to open the M5.5 screws.
https://www.thingiverse.com/thing:4760247
Second one is a replacement for the cable outlet to fit a Pro Micro for internal conversion.
https://www.thingiverse.com/thing:4760261
Both work quite good, though the wrench should ideally printed with ABS.
PLA worked too, but opening and closing the case twice pretty much broke it already.
