Linux DAC USB headphones+mic+speakers suggestions?
- matt3o
- -[°_°]-
- Main keyboard: WhiteFox
- Main mouse: Anywhere MX
- DT Pro Member: 0030
I'm looking for an external Linux-compatible USB audio card able to drive both headphones+mic and speakers (so yeah technically both DAC and ADC). I don't need audiophile quality, just decent linux compatibility, hiss/click free audio and good mic input.
The one I could find is the Creative Sound Blaster X7 which is ugly as hell but it seems to check all the boxes... and it's possibly more than I need
Do you have any suggestions?
- matt3o
- -[°_°]-
so... we agree
- matt3o
- -[°_°]-
also found this https://mayflowerelectronics.com/arc-mk1-1/ that looks sweet but I can't find it in Europe.
Ouch! That's expensive for a sound device.
I'm currently using a CalDigit Thunderbolt dock myself, which is just as pricey, but does give me a desktop workstation for the price. Just plug my laptop in with one cable and everything's connected. It's got optical audio out as well as headphone analog and line-in sockets, which do the trick for my playing around with music in Logic. But it's Thunderbolt or bust, and makes no mention of Linux support.
USB mixers and audio interfaces for desktop musicians may be what you're looking for. The entry models have less outputs, which is likely all you want. And some of them have pleasingly weighted volume knobs…
- matt3o
- -[°_°]-
Also found this https://www.bursonaudio.com/products/playmate/ ... but can't find it over here. Not a huge fan of the specs but I could live with it.
- zuglufttier
- Main keyboard: IBM Model M SSK
- Main mouse: Razer Abyssus
- DT Pro Member: 0226
If it's in your price range: Motu M2
In my experience, it's the best sound device you can get for that kind of thing right now. If your headphones are not too hard to drive then is also has a very competent headphone amplifier.
Measurements: https://www.audiosciencereview.com/foru ... ace.19911/
- matt3o
- -[°_°]-
that's pretty sexy and quite overkill. It's a kind of different beast compared to what I need... in that range I've found the Rode Ai1 which is small, sweet and cheaper (or any entry level Focusrite).zuglufttier wrote: 01 Apr 2021, 17:02 If it's in your price range: Motu M2
- Daniel
- Main keyboard: Various
- DT Pro Member: 0028
I'm using an Audinst HUD-MX2 since a few years on Linux and Windows. One of the main reasons I've bought it is that it's easy to switch between head phones and speakers and it has an optical input as well. Finding sth. with comparable features was pretty hard a few years ago.
EDIT: sorry I've should have read your post in more detail. The Audinst HUD-MX2 doesn't have a mic-input.
- HAL
- Main keyboard: IBM Model F (Unsaver)
- Main mouse: Logitech MX Laser / MX 518
- DT Pro Member: 0025
How about a solution consisting of two things:
an USB Audio Interface like the Behringer U-Phoria UMC202HD for € 63 (thomann.de)
and a separate class D amplifier like the Lepy LP-2020A HiFi Stereo Digital Power Amplifier Class D (ebay)
- DT Pro Member: 0049
I've got a Focusrite Scarlett 2, but ALSA doesn't allow me to change the volume on my Arch Linux box. Not sure what's going on there, whe I open alsamixer then it complains that it couldn't list all channels or couldn't interact with a mixing bus or something...matt3o wrote: 03 Apr 2021, 09:34that's pretty sexy and quite overkill. It's a kind of different beast compared to what I need... in that range I've found the Rode Ai1 which is small, sweet and cheaper (or any entry level Focusrite).zuglufttier wrote: 01 Apr 2021, 17:02 If it's in your price range: Motu M2
It does produce output but I've never tested recording.
- HAL
JBert wrote: 03 Apr 2021, 14:48 I've got a Focusrite Scarlett 2, but ALSA doesn't allow me to change the volume on my Arch Linux box. Not sure what's going on there, whe I open alsamixer then it complains that it couldn't list all channels or couldn't interact with a mixing bus or something...
I also got a Focusrite Scarlet 2 and I use it for ripping vinyl (with a preamp of course). I don't use ALSA to set any levels (neither record nor output). Thats what the gain knob on the Focusrite (recording) or the volume knob on the preamp is for.
