IBM 3278 beamspring keyboard restoration and usb convert
- lucar
- Main keyboard: Wyse PCE
- Main mouse: Logitech MG900
- Favorite switch: Alps Blue
Hi,
I completed a restoration project of an IBM 3278 series terminal beamspring keyboard and usb convertion.
I have to thank Deskthority user Pandrew for his great design of a low cost and effective beamspring usb converter and my friends Andrea and Marco from the italian mechanical keyboard "CCC" group for the patience and support in this project.
Here is a video with the summary of all the work involved.
Cheers
Luca R.
Cheers
Luca R.
Tahoma
- Main keyboard: Unicomp
- Main mouse: Kensington Orbit trackball with scroll ring
Wow, this is really cool!
Amazing labor of love! Beautiful result from a badly deteriorated start point.
Love the aesthetics of the keyboard, as well as the other vintage equipment used to fix it (blue vice, soldering iron)! And I also love the marine cold weather gloves.
Very creative use of dive weights to boot.
Was this keyboard found while scuba diving?
Thanks again for posting this great video!!!!!!!!!
- lucar
Thank You!!Tahoma wrote: 20 Mar 2021, 16:54 Wow, this is really cool!
the keyboard rested , abandoned, in an open field exposed to weather for years, thats' why it was so rusty. Really, I had to figure out how to restore or replace every single piece. Fortunately, the most important parts , the switches, were in good conditions so I did proceed with the restoration. Actually, the thing that is left, is to understand how to wind new springs, I wish I could make them in stainless steel.
Thanks again
Luca
Tahoma
You are welcome! Nicely done.
- darkcruix
- Main keyboard: Brand New Model F F77 Keyboard
- Favorite switch: Buckling Spring / BeamSpring
- DT Pro Member: 0209
One of the best restoration videos I have seen so far ... very impressive work, including the complete re-creation of the switch plate(s).
- TheInverseKey
- Main mouse: M570
- DT Pro Member: 0216
This right here is why I keep coming back to DT. Seeing a rusty old board being brought back to life with the amount of care and attention to detail always gets me to finish the next project. Thanks for posting!
- SneakyRobb
- THINK
- Main keyboard: KB-5161A, F122, Dc2014, Typeheaven, Beamspring FXT
- Main mouse: MX518 Legendary
- DT Pro Member: 0242
Very nicely done! Great job
Riptide666
- Main keyboard: BS
- Favorite switch: BS
Nice work! Did you repaint the case?
- lucar
Hi!
Thank You all for the kind words!
Yes I did repaint the cover, but as I anticipated in the audio , due to covid, I could'nt shoot the video of the paint job. I have no paint code because I just brought everything to a "body shop" and they have something like a colorimeter and a machine that blends paint color to reproduce a close one to the original . The color sample was taken from the plastic door of another destroyed keyboard, so, that is the work of a professional, it goes bejond my possibilites in my small garage.
There is also a lot of undocumented work relating to the one by one cleaning of switch cases and components, derusting of the solenoid , rebuilding of the door hinge and spring and a lot of initial failures with the spacebar stab for example.
All of this has been not easy since I have rather basic tools to work with.
I did design the barrel and bottom closure and made it cut and bent in a local shop, they have great laser cutting and bending machines that made it possible. This comes from past experiences designing keyboard plates if You check my past videos, so it's not been a terrible effort there.
All this took a lot of time, mostly to figure out how to solve problems like opening switches without breaking one or remove the old spacebar stabilizer.
Luca
Luca
- Muramasa
- Main keyboard: IBM 3276 Cyrillic
- Main mouse: Razer Deathadder
- Favorite switch: Beamspring / SKCM Blue
I've restored a pretty rusty 3101 but this is another level! amazing work, an inspiration for sure. I also couldn't believe the work you put into modelling and producing replacement switch and back plates! Are these resources you'd consider sharing with the community?
- darkcruix
I was wondering the same, if the files are available.Muramasa wrote: 21 Mar 2021, 13:16 I've restored a pretty rusty 3101 but this is another level! amazing work, an inspiration for sure. I also couldn't believe the work you put into modelling and producing replacement switch and back plates! Are these resources you'd consider sharing with the community?
- shine
- Main keyboard: F122
- Main mouse: Deathadder Elite
nice work! good job mate
- depletedvespene
- Main mouse: Logitech G700s
- DT Pro Member: 0224
Outstanding restoration.
- lucar
Thank You all again for the nice feedback.darkcruix wrote: 21 Mar 2021, 14:23I was wondering the same, if the files are available.Muramasa wrote: 21 Mar 2021, 13:16 I've restored a pretty rusty 3101 but this is another level! amazing work, an inspiration for sure. I also couldn't believe the work you put into modelling and producing replacement switch and back plates! Are these resources you'd consider sharing with the community?
I'm thaking into consideration to publish the barrel prject files. I'm hesitating because it's not a cut and go thing like a simple plate as we're used to , it needs some explanations for those who evantually would dare to try and smart people at the cutting shop.
I'll see how I can publish it , I'll keep You posted.
Luca
orihalcon
- DT Pro Member: 0190
Very nice restore! I’ve had one like this in the past and what really kill things is if the springs and stems are rusted though, so I’m glad yours was salvageable!
How did you restore the case? Chemicals vs sandblasting, or both? What type of paint?
- lucar
I gave the case to a car paint shop and a color sample and they sand blasted, grouted, powder coated it. Once You have the electronics, chassis and everything working, You can spend in a professional paint job , otherwise impossible in the limited space of a garage. I decided not to buy a sand blasing machine nor to go with paint spray cans, You can use them to salvage a plate but not to finish a case in my opinion.orihalcon wrote: 22 Mar 2021, 12:30 Very nice restore! I’ve had one like this in the past and what really kill things is if the springs and stems are rusted though, so I’m glad yours was salvageable!
Luca
- lucar
I had a hard time to convince a local plastic laser cutting shop to cut me the foam from the cad model but after 5 attempts then came the pandemic and I had to do it the old wayZyBeR wrote: 26 Mar 2021, 11:59 Very impressive! Though I must admit I laughed a bit when you used a pen to outline the holes just after showing a cad model of the part when then was laser cut and bended![]()
hypkx
- Chasing the Dream
- Main keyboard: redscarf III
Hello Lucar, I tried to reach you via PM, but sadly the system doesnt work anymore. Could you maybe send me the files for the barrelplate assembly, because I am currently also restoring a beamspring, which also needs a new plate?
