[WTB] IBM Model F Personal Computer Logo
- Lalaland124
- Main keyboard: 3278
- Favorite switch: Beamspring
Hey, I am looking for a silver logo for my IBM Model F keyboard from the IBM personal computer. Maybe someone has one lying around
- XMIT
- [ XMIT ]
- DT Pro Member: 0093
If you don't find one, they're not /that/ hard to make. What I would do is find some thin stainless steel sheet metal, cover it with Kapton tape, use a laser cutter to etch away a stencil from that tape, powder coat over the stencil, then remove the stencil and cut to size. You'd get a nicer badge than the originals this way.
Good luck!
Good luck!
- Lalaland124
Didn't know that - Thanks for the advice
