[WTB] MF68 PCB
serenitybomb
This is a long shot, but does anyone have a spare MF68 PCB they'd like to sell?
serenitybomb
Oh wonderful! Whats the difference between the two, and does the Tragicforce work with stock MF68 qmk?Rayndalf wrote: 18 Apr 2021, 11:20 I have a couple, do you want a stock PCB (with diodes for NKRO) or a Tragicforce PCB?
Rayndalf
- Main keyboard: Kinesis Model 130
- Main mouse: Logitech M-S48, Razer Viper
- Favorite switch: MX Browns
As Muirium noted it's the kit from here https://keeb.io/products/mf68-magicforc ... cement-kitserenitybomb wrote: 18 Apr 2021, 23:52Oh wonderful! Whats the difference between the two, and does the Tragicforce work with stock MF68 qmk?Rayndalf wrote: 18 Apr 2021, 11:20 I have a couple, do you want a stock PCB (with diodes for NKRO) or a Tragicforce PCB?
The tragicforce PCB runs QMK and uses a promicro. I need to finish up some diodes before I can confirm it's working.
I'm not sure if the stock PCB is reprogrammable. It's better than the non NKRO PCBs my first MF68 had and the diodes make it possible to handwire to the rows and columns to a promicro and get it on QMK in a pinch.
I also have a completely disassembled MF68 (case, cap and stabs etc) and a second set of original caps.
I'll get a photo once I find it.
- DT Pro Member: 0011
serenitybomb
Neat, I'll take the Tragicforce PCB! I'm also using a disassembled Magicforce for my build lol. PM me with the info!Rayndalf wrote: 19 Apr 2021, 02:19As Muirium noted it's the kit from here https://keeb.io/products/mf68-magicforc ... cement-kitserenitybomb wrote: 18 Apr 2021, 23:52Oh wonderful! Whats the difference between the two, and does the Tragicforce work with stock MF68 qmk?Rayndalf wrote: 18 Apr 2021, 11:20 I have a couple, do you want a stock PCB (with diodes for NKRO) or a Tragicforce PCB?
Rayndalf
I'll pm you the moment find itserenitybomb wrote: 19 Apr 2021, 03:38 Neat, I'll take the Tragicforce PCB! I'm also using a disassembled Magicforce for my build lol. PM me with the info!
Just to clarify you already have the daughter board used with the original PCB to route the USB port?
I don't mind just selling the QMK PCB, but I'd love to sell all of it in a bundle.
What switches are you planning on using?
serenitybomb
Yeah, I've got an entire original Magicforce 68, so I have the daughterboard that comes with it. Just want a programmable PCB in it instead of the stock one since I hate the stock FN shortcuts lol.
I'm planning on using Gateron Clears since they're the lightest switches I've found. I'm planning to use this keyboard as my gaming one and I find that I tend to get finger aches from holding down the WASD keys for long periods of time, so I'm hoping that the light spring weight mitigates that.
