Beige, gr(a/e)y or black?
Grey? But Earl Grey is nothing of the sort.
I'd vote for Grey if Gray were an option. But as things stand, I've no idea what your poll is truly asking. Perhaps it's time to populate an experimental planet with observant mice, to find out?
- Bjerrk
Use your imagination, Mu.Muirium wrote: 12 May 2021, 11:43 Grey? But Earl Grey is nothing of the sort.
I'd vote for Grey if Gray were an option. But as things stand, I've no idea what your poll is truly asking. Perhaps it's time to populate an experimental planet with observant mice, to find out?Spoiler:
(Nobody said "Grey, like Earl Grey". It clearly says "... as in ... ". Also, you're overthinking this
Although I applaud your methodology, which will surely yield 0x000042
- DT Pro Member: 0011
Do you mean as in "Route ..." or as in "Order ..." ?Bjerrk wrote: 12 May 2021, 11:51 Although I applaud your methodology, which will surely yield 0x000042
- ddrfraser1
- Main mouse: MX MASTER
I suspect the pollster takes milk in his tea
- Bjerrk
Well, surely 42 is the answer, but since we're discussing colors ...Findecanor wrote: 12 May 2021, 14:02Do you mean as in "Route ..." or as in "Order ..." ?Bjerrk wrote: 12 May 2021, 11:51 Although I applaud your methodology, which will surely yield 0x000042
Milk, and a healthy dose of lysergic acid.
- kbdfr
- The Tiproman
- DT Pro Member: 0010
Did you say "colours"?Bjerrk wrote: 12 May 2021, 15:14[…] but since we're discussing[/color][/b] [url=https://www.htmlcsscolor.com/hex/000042] colors ... […]
- Bjerrk
I did indeed! A bit of Donovan is always appreciated, whether in colour or not!kbdfr wrote: 12 May 2021, 18:11Did you say "colours"?Bjerrk wrote: 12 May 2021, 15:14[…] but since we're discussing[/color][/b] [url=https://www.htmlcsscolor.com/hex/000042] colors ... […]
.Spoiler:
