Some Model Fs (Ellipse's New Model F, the Model F AT etc) feel significantly lighter than Model M buckling springs, and I have to say that I prefer the lighter keyfeel somewhat.
Since I had a few of Ellipse's Model F springs lying around, I decided to try and swap them into a couple of Model Ms (a 1987 IBM one and a 2000s Unicomp one). I had a bit of trouble getting it to work well in the IBM Model M (not sure why yet), but to my surprise the springs worked perfectly with the Unicomp one, and the spring-swapped keys (the arrow keys) now feel significantly lighter.
I'm pretty excited about this, since the stiffness of the keys is essentially the only complaint I have about the Model M.
The really exciting thing would be if it turned out to be possible to order similarly spec'ed springs (length, diameter, spring constant) without having to resort to harvesting old Model Fs (
(Note: There is an old thread on Geekhack discussing this, where one person tries comparing with XT springs, and another conjectures that it would feel the exact same. I can only say that the difference is highly noticeable with Ellipse's F springs in this Model M)
