Is there anyone on the forum based in the USA that can repair/reassemble a model F AT keyboard? I cleaned it and was real dumb, and took of the spacebar. I tried everything non destructive I could to put it back together, but I had no success. I then took it apart to try to reattached the space bar, and then found it too difficult to put it back together. Is there someone here that I could send to?
Thanks.
Model F AT Repair?
ParachutePeople
- Main keyboard: Keychron Q1
- Main mouse: Logitech G502
- thefarside
I’m not sure if he works with Model F keyboards but he did a great job on my Model M. Might be worth a shot reaching out:
https://www.clickykeyboards.com/contact-us/
- -Space-NATO-
- Main keyboard: IBM 3278 / Leading Edge DC-3014
- Main mouse: Who cares about mouses here?
- Favorite switch: Beamspring / Blue Alps
Do you have some pictures? Not so hard if you know what you're doing.
- hellothere
- Main keyboard: Lots
- Main mouse: CST2545W-RC
Yes, lots.ParachutePeople wrote: 23 Feb 2022, 21:35 Is there anyone on the forum based in the USA that can repair/reassemble a model F AT keyboard?
My hourly rate is $960.00, one hour minimum.
I'll go with -Space-NATO- and recommend posting pics. It's definitely hard to do if you don't have the proper tools.
