I want to create a macro that will type certain phrases out, such as Thank You!, but typing:
MAKE LSHIFT
PRESS T
BREAK LSHIFT
PRESS H
PRESS A
is really getting old, especially when I want to set up a half dozen of these things.
Does anyone have a script that will let me enter a phrase and spit out a completed macro block I can just copy and paste into my sc file?
I'm sure I can bang something out in Python this evening, but why reinvent the wheel?
If no one has one, and would like a copy of whatever I come up with, let me know.
Does anyone have a script to make Soarer's Converter Macros
apastuszak
- Main keyboard: Apple Extended Keyboard (Salmon Alps)
- Main mouse: Kensington Slimblade Trackball
Specifically for typing (pass)words?
I’ve moved all my macros into Karabiner but something like this would have been useful back when I did much the same in Soarer.
apastuszak
This is a work computer. I am not allowed to run anything like Karabiner or AutoHotKey. So, I need a hardware-based solution, like a Soarer's Converter.
I guess I am writing a script for myself.
Yep.
I did a few of these but not enough to put on the long wellies and wade into scripting. Regex is g(ob)|di:gūk to me else I’d have done it.
- jsheradin
Something like this should work (I haven't tried it though):
You'd need a catch case for anything that's not a letter but you get the idea.
for char in input():
if char.isupper():
print("MAKE LSHIFT\nPRESS " + char + "\nBREAK LSHIFT")
elif char == " ":
print("PRESS SPACE")
else:
print("PRESS " + char)
apastuszak
So, I learned something useful. My macro was triggered when I pressed RSHIFT and F1. Well, the caused the characters in the macro to type out as if I was holding the shift key down. To this, the first line in the macro has to be BREAK RSHIFT.
Has the same problem with macros to launch applications. LSHIFT + F3 would launch an app, by pressing LGUI waiting 100, breaking LGUI and typing the name of the application and pressing ENTER. Could not figure out why it wasn't working.
