What solenoid is closest to beamspring ones? (Modelfkeyboards aside)
vyquad
- Main mouse: G502
- Favorite switch: IBM Capacitive Buckling Spring
ive had no luck finding a solenoid that sounds like the ones IBM made (This is being tested inside a model f xt and yes i know case acoustics is a factor) im excluding joes solenoid since i have it and tested it
