This pic indicates a new cost reduced Cherry Corp switch (or a VERY good copy of the cruciform stem with thicker horizontal vs vertical part of the cross.
http://www.overclock.net/t/1268117/dear ... t_17448040
Another mini pic here (although spec there says Cherry MX)
http://www.newegg.com/Product/Product.a ... 6823839010
Reminds me of the cost reducing shift from ALPS Mechanical to Alps Rubber Dome.
Anybody heard about these?
Yah, the keyboard is fugly but that is not the point of this thread....
New Cherry Switch On Azio/Dearmo Keyboards?
ripster
- Main mouse: Mickey
To answer my own post I now think it is a plastic condom alá the TG3 BL82 keyboards. See how the switch is recessed?
Clever!
Finally a feature that makes sense for the gaymerz that barf (OCN) or shit(GH) all over their keyboards.
WHAT A FUGLY KEYBOARD! At least it is Chinese IBM Clone Helvetica and has a REAL volume dial. Love them volume dials!
http://deskthority.net/news-reviews-f4/ ... t1184.html
Clever!
ChuckFinlay
I love how those "professional hardware reviewers" on youtube "review" those keyboards.
Didn't get to see the switches in any of their videos. The French guy said he got the Dearmo at Cebit, I still think only the other one could be legit. If at all.
- DT Pro Member: 0011
The "keyboard condoms" that I have seen before have had smaller circular holes that attached to the key cap's stem. This seems to have a larger hole that does not affect the action.
I think that the sheet covering the switches might just be a cheap and efficient way of getting soft landing pads without having to attach them manually to each key.
I just hope that there is some air between the key cap and the rubber when the key is at the bottom -- otherwise, if the keycap seals against the rubber then there can be a weird suction effect causing the key to stay pressed for a second more after you have released it.
ripster
I've asked the guy at OCN to poke at it a bit. Could be a simple thin plastic shell like the keyboard covers that come with Filcos but opaque.
- Trent
- Main keyboard: IBM Model M
Reading the newegg reviews I doubt this is an official cherry switch "with a condom on it". It is an imitation at best. Just read all of the reviews where the keys malfunction after 2 weeks of usage. Cherry switches wouldn't do this me thinks.
- kint
- Main keyboard: g80-8200/ FK-2002
- Main mouse: genius netscroll optical gen1
- Favorite switch: MX clear/ Alps white comp
no one noticed the seemingly huge distance between the edges of the switch on to the other?
It can be seen on the Dearmo "W" pic but is better visible on neweggs pic. Imo no way that this is a regular MX switch with even a rubber cover on top of that, not even if its condom thin on the sides. Or they messed with the keycaps width a lot.
Furthermore the switch seems to have much less height compared to the width, adding the recessed stem on top of that this doesn't fit to the rather cubic MX in my mind.
If this truly is an OEM cherry switch, i'ld throw out a wild theory of a MX 2.0, cheaper, waterproof, probably not openable and with less height (would be the only pro imo).
@Trent:
A lot of the reviews talk of full blocks failing, not just single keys. One claims being cured by reboots of the PC. Might as well be a faulty controller or PCB traces or....
@Trent:
