Laser 2269
Switches: SMK 2nd generation clicky MX Mount. Very light and has a decently soft and high pitched click.
Caps: Thick doubleshot ABS made by VTech in it's OEM profile.
Mount / Plate: Plateless tray mount. I removed some of the screws in the alphas to give it a bit more flex.
Fujitsu FKB4700-101
Switches: Fujitsu Peerless Type 2. Feels similar to IBM's Membrane Buckling Springs but as a dome with slider switch.
Caps: Thin PBT dye-subs made by Fujitsu in it's OEM profile.
Mount / Plate: Plastic barrel plate with a steel backplate.
Chicony KB-5301
Switches: Chicony Membrane Buckling Springs
Caps: Medium thick pad printed ABS. made by Chicony? in some sort of OEM profile.
Elektronika MC-7004N
Switches: Elektronika Capacitive Buckling Springs. Feels pretty decent surprisingly, a bit lighter and less tactile than the real thing.
Caps: Medium thick something or other. Plastic can yellow so it's probably ABS but who knows since it's from the Soviet Union.. I think the printing is silkscreened? Caps are uniprofile with a curved assembly.
Mount / Plate: Steel barrel plate with a steel back plate.
IBM 1395158 Model M
Switches: IBM Membrane Buckling Springs. If you don't know how a Model M feels shame on you.
Caps: Thick PBT dye-subs made by IBM Greenock in IBM's OEM profile.
Heroic Branded Cantech TK-105M
Switches: Cantech Membrane Buckling Springs. It feels and sounds pretty inconsistent sadly. A shame since the keys near the screws holding it together feel pretty great.
Caps: Thin pad-printed ABS made by Cantech in it's OEM profile.
Mount / Plate: Integrated plastic barrel plate.
Alps SM-102?
Switches: Alps Membrane Buckling Springs. This still needs to be restored so I don't have my full thoughts on it yet.
Caps: Thin pad-printed ABS made by Alps in it's OEM profile.
IBM Model F XT
Switches: IBM Capacitive Buckling Springs. My favorite clicky switch.
Caps: Thick PBT dye-subs made by IBM USA in it's Buckling Spring OEM profile.
TI-99/4A
Switches: Alps SKCC Cream. Very smooth and I don't even mind the weighting but it's just not my cup of tea for linears. In general I don't like pre-DIN linears.
Caps: Medium thick doubleshot ABS made by Alps in it's SKCC profile.
Mount / Plate: Top mounted steel plate.
Fujitsu N860-2500-T153
Switches: Discrete Fujitsu Clicky FES-301e (FLS 3rd gen) Very light with a tiny tactile bump. It sounds like your typing on jar lids, if you've ever tried Futaba MA it's kinda like that but sounds less harsh. Sadly mine aren't in great condition so they are a bit scratchy but in good condition they are super smooth.
Caps: THICC doubleshot ABS made by Fujitsu in it's "Tombstone" profile.
Data General One Keyboard Module
Switches: Semi-discrete Fujitsu Clicky FES-301e (FLS 3rd gen)
Caps: Thick dye-sub PBT made by Fujitsu in some sort of special profile for Data General laptops.
Epson Q203a
Switches: Fujitsu FES-370 (Lever Action). Medium weighted tactile switch with a tiny little bump that's a bit rounded feeling, I guess it's not that surprising since it's supposedly using a metal dome. I'll be taking it apart soon and documenting it since the pics for the switch that exist kinda suck. Nevermind Mandarbmax made a documentation video before I could make a post https://www.youtube.com/watch?v=amH47ICdJEo
Caps: Thin PBT dye-subs made by Fujitsu and in it's OEM profile.
Mount / Plate: Steel plate held in by hopes and dreams.
Northgate Omnikey/102
Switches: Alps SKCM White (Pine)
Caps: Thin doubleshot ABS made by Focus in it's OEM profile.
Mount / Plate: Top mounted steel plate. It's only mounted with 4 screws (2 on each side) so it feels softer than you'd expect out of a steel plate. A lot of vintage boards are mounted like this but given the length of this it's a bit more noticeable here.
Amiga 1000
Switches: Mitsumi KCT-2. Mitsumi KCTs and other Mitsumi horizontal spring switches are imo some of the best tactiles made and probably the most underrated thanks to the undeserved reputation Chyros has given Mitsumi.
Caps: Thin dye-sub PBT made by Mitsumi in it's OEM profile.
IBM 93Y1131 MCANPOS
Caps: Thick pad-printed ABS made by IBM in their buckling sleeve POS profile.
AT&T 56k 420 ADA.
Switches: AT&T Magnetic Separation. Switches that use magnets for tactility feel very different from any other switch so it's hard to describe. It's foam and foil but the foam is pretty thin so it has a soft bottom out that doesn't really feel mushy.
Caps: Medium thick dye-sub PBT made by AT&T in it's magsep OEM profile.
Mount / Plate: Aluminum plate held in by hopes & dreams.
Fujitsu N860-4747 module
Switches: Fujitsu Peerless Type 1. I think they feel different from the more common Type 2 but I don't have enough examples to say for sure.
Caps: Medium thick dye-sub PBT made by Fujitsu in it's OEM profile. Well this is a mix between Tandy 3000 alphas and 4747 mods, the Tandy 3000 caps are pretty scuffed and the 4747 caps were in better condition so I just swapped them around. Didn't change the mods since the stabs are different.
NTC KB-5060N
Caps: Thin pad printed ABS made by someone (idk who) in a OEM profile.
Datacomp JMC-700a
Switches: Cherry MX Black
Caps: Thick doubleshot ABS made by Cherry in it's Cherry profile.
Packard Bell M-8700
Switches: Futaba MA.
Caps: Thick doubleshot ABS made by Seijin in it's OEM profile.
Zenith Z-150
Switches: NOS White Alps with Amber Alps springs and clickleafs.
Caps: Mediumish thick doubleshot ABS made by Alps Electric in it's OEM profile.
Tandy 3000
Caps: Medium thick dye-sub PBT made by Fujitsu in it's OEM profile. 4747 alphas and 3000 mods, see the 4747 post for why.
Commodore PC-5/10 (Cherry G80-0499/1)
Mount / Plate: Plateless tape mount (Hopes & dreams mount but the PCB is mounted to the top case by two pieces of tape lol)
Xerox 6085
Caps: Medium thick dye-sub PBT made by Alps in it's OEM Profile.
Mount / Plate: Steel plate held in by plastic clips.
Oki HMB-35957-14
Caps: Medium Thick dye-sub PBT made by Oki in it's OEM profile.
Mount / Plate: Plastic Barrel Plate with a steel backplate.
Wyse AT Standard
Caps: Thin ABS doubltshots made by Comptec in it's DCS profile.
Mount / Plate: Top mounted steel plate (It's held in by one screw so it's mostly hopes & dreams mount lol)
NMB 112083-005
Caps: Medium Thick dye-sub PBT made by NMB in it's 725 OEM profile.
Ardent Computer 130·00020·01 (Alps KC71CM0050)
Mount / Plate: Mount / Plate: Steel plate held in by hopes and dreams.
