Semi-silent tactile switches w/o mushiness?
Mumpitz
26 Aug 2023, 20:15
Hey there,
do you know any tactile semi-silent switches that are noticeably quieter than average while not feeling mushy?
I recently tried the Geon HG Yellow with the "innovative" Haimu stem design. While being dead silent the typing experience is not too impressive imo. The bottom out does still feel quite mushy, like typing on a conventional rubber-damped switch.
Are there any switches that combine the best of both worlds? Tactile, noticeably quieter than average with still a good typing experience?
Appreciate your help!
Regards,
Mumpitz
davkol
26 Aug 2023, 20:53
I wish I could tell, but the fact of the matter is that my quietest keyboard has been ErgoDox with vintage MX Black switches that I didn't bother dampening in the end. Most of the noise comes from my fingertips hitting keycaps.
Actually, that kind of answers the question: you can dampen the upstroke, sure, and use springs that help prevent you from bottoming out; that avoids both the respective noise and the mushiness associated with dampening it.
Delta Research
26 Aug 2023, 21:04
If you're willing you could stem swap the Haimu silent switches with something like an MX clear stem. The bottom housing has holes in it that makes the switch quieter, so that could work for you.
Lubing the switches and/or putting foam in the case can also help lower the overall volume of the keyboard as well.
Mumpitz
26 Aug 2023, 21:58
Thanks for your replies! :)
davkol wrote:
26 Aug 2023, 20:53
springs that help prevent you from bottoming out...
Ok. But that would require stronger springs and higher actuation force, right?
Delta Research wrote:
26 Aug 2023, 21:04
Is there anything you can recommend? Something tactile with roughly 50-60g?
26 Aug 2023, 21:04
My board is damped quite well already: Monsgeek M1. I feel like the switch itself is more important here.
Lubing might be a further thing to consider, indeed.
davkol
26 Aug 2023, 22:28
Mumpitz wrote:
26 Aug 2023, 21:58
davkol wrote:
26 Aug 2023, 20:53
Not quite. There's the spring length too; or it can be nonlinear.
See, my vintage MX Black switches have springs swapped for old sprit's 78g springs inspired by Cherry MX Clear. These have a steeper force curve, i.e., they're relatively easy to compress early on, but the force ramps up quickly, so they're relatively harder to bottom out.
There are more options these days.
RBC
29 Aug 2023, 19:23
Have you tried the TG3 "Copre" mod on silent linears?
engr
29 Aug 2023, 21:09
Do these have to be discrete switches?
If not, Topre boards can be made very silent and do not have a mushy feel.
Niz boards use the same principle (capacitive rubber dome) as Topre. Some actually prefer their feel and sound more.
29 Aug 2023, 21:50
Some are objectively wrong. ;)
Delta Research
29 Aug 2023, 22:01
Some are objectively right. ;)
29 Aug 2023, 23:47
Something tells me this dispute won’t end well.
engr
01 Sep 2023, 20:20
Muirium wrote:
29 Aug 2023, 21:50
I have only tried Topre, so I can't comment on how Niz feels, but I can see how its sound can be appealing. It sounds... fuller? Meatier?
Mumpitz
02 Sep 2023, 21:52
Tried the U4TX meanwhile and kinda like them. But the travel is rather on the shorter side. Its spec'd with 3.7mm but I can only measure 3.3mm. Sound is quite nice, though. It strikes the middle between loud and quiet while feeling more or less clean on the bottom out. More or less, because there is still a tiny bit of rubber on the stem facing downward (Cherry MX Silent style). Nowhere near the mushiness of regular silent switches though.
My next candidate will be the Kailh Deep Sea. Might remove its rubber on the bottom to make it feel less damped while maintaining the upstroke dampening.
03 Sep 2023, 12:24
engr wrote:
01 Sep 2023, 20:20
I know this will sound fanboy, but it's my honest opinion whenever this comes up: different switches in different chassis is no comparison at all, especially in a vid and not in person.
But FWIW I really don't like the way that Niz 'sounds.' Way too smacky. :P
To be fair, they're also hammering the shit out of their Realforce. Easy on those keys, cowboy, this ain't no MX clear!
Tribal
04 Sep 2023, 01:22
engr wrote:
01 Sep 2023, 20:20
Muirium wrote:
29 Aug 2023, 21:50
There’s some setting most keyboard YouTubers are using that amplifies even the tiniest sound. I’ve used regular 55g Topre and 45g silenced Topre and neither sounds like that unless I have my ear literally pressed to the keyboard. From a normal sitting position, either is whisper-quiet and I’d feel comfortable using one in a library. Each is as quiet as normal rubber dome switches and is slightly quieter than scissor switches.
Also, I just got some Boba U4 silent and they’re…silent. They feel like a hybrid of a Holy Panda and Topre and are about 90% as good as either.
04 Sep 2023, 09:37
I often literally use my silenced HHKB in a library:
And it's definitely quieter than most MacBooks. Some people piledrive those with their two good typing fingers! :lol:
apastuszak
13 Sep 2023, 21:55
Matias makes a quiet click switch, which is not bad.
I think the quietest mechanical I own that doesn't feel "mushy" to me is the Apple Extended Keyboard II with cream alps switches.
But that's a beast of a keyboard. Not something you would carry around in your bag.
guidemetothelight
14 Sep 2023, 08:10
26 Aug 2023, 21:04
Or just use this.
Great switch. no mush, good tactility, affordable
Edit: Drink Coffee first, then read DT threads.
14 Sep 2023, 11:02
DT's where you come to once you're caffeinated. Ease yourself awake by browsing keyboard porn first, before tangling up in all the words. ;)
