![Image](https://imgur.com/8vCHd1P.jpg)
![Image](https://imgur.com/zAQhvdh.jpg)
Hello everyone,
I am so excited to announce that MKC’s second series-MKC65 will be available to everyone in two days! If you are looking for a truly entry-level customized keyboard, I believe it will not disappoint you. Without further ado, read on for more details about the MKC65 pre-order.
MKC65 Pre-order information
MKC65 Variation and Price
MKC65 Pre-Order Page
MKC65 Prototypes
MKC65 Renders
An MKC Titanium Switch Puller
Pre-order Time:
From January 15th to February 15th
Estimated Delivery:
The delivery is expected to be around two months after the pre-order ends. Due to the influence of the Spring Festival holiday and potential adjustments in the order quantity, there might be a slight variation in the delivery time.
Vendor List
US: KeebsForAll
US: Cannonkeys
Canada: Ashkeebs
UK: Prototypist
Germany: KEYGEM
Italy: Coffeekeys
AU: SwitchKeys
South Korea: Geonworks
Singapore: Mecha.Store
Japan: Basekeys
Vietnam: MOKB STORE
Philippines: Zion Studios
Malaysia: Rebult Keyboards
Indonesia: KeebsMark
Thailand: NTCH Keys
Taiwan: PNKeyboard
Bangladesh: Cybertronics
Chile: Fancy Customs
International: Mykeyclub
MKC65 information
Features
○ Compact 65% layout.
○ 6.5° typing angle for a more comfortable typing experience.
○ 100% CNC-machined with 6063 aluminum case.
○ Alu Internal Weight, adding to the overall weight and stability.
○ Simultaneously support two functional modules (Rotary Knob & Light Sign), also compatible with ○ JRIS80 Rotary Knob/LED Light Sign.
○ Three-in-one design with Top Mount, Plate Gasket Mount, and PCB Gasket Mount for an enhanced keyboard experience.
○ Supports tri-mode PCB (Wired, Bluetooth and 2.4ghz).
○ Supports Plate and Plateless Build.
○ Supports Caps Lock Indicator Light.
○ 2 x 2200mha large battery capacity.
MKC65 Specifications
○ Typing angle: 6.5°
○ Front height: 9 mm
○ Material: Full CNC 6063 aluminum
○ Dimension: 319.85*110.3*29.95mm
○ Three-in-one Structure: TOP Mount / Plate Gasket Mount / PCB Gasket Mount
○ QMK/VIA Supported(wired)
○ Support PCB stabilizers
○ Unbuilt Weight
With PVD WEIGHT: 1.23kg
With Alu WEIGHT: 1kg
○ Built Weight
With PVD WEIGHT: 1.45kg
With Alu WEIGHT: 1.22kg
Three-in-one structure (Top Mount, Plate Gasket Mount, and PCB Gasket Mount)
is a versatile keyboard mounting system that combines the distinctive features of these three structures for comprehensive performance.
Users can customize based on personal preferences and usage scenarios.
○ TOP Mount
○ Plate Gasket Mount
○ PCB Gasket Mount
The four keys located on the rightmost row of the MKC65 keyboard (Insert, Delete, PgUp, and PgDn keys) can function as a customizable module. The Rotary Knob and Light Sign can be interchanged among any four keys, and they don't necessarily need to be connected together.
However, please note that it supports a maximum of two functional modules simultaneously. For example, 2 * Rotary Knob, 2 * Light Sign, or 1 * Rotary Knob + 1 * Light Sign.
8 Case Options:
○ 4 E-coat case:E-white, Milky White, Pink, Mint Green
○ 4 Anodized Case: Wine Red, Black, Grey, Silver
○ 4 Alu Weight: Gold/ Silver/ Rose Gold/ Black
○ 4 PVD Mirror SS Weight: Gold/ Silver/ Black/ Chroma
○ Wired Flex Cut Hotswap PCB
( 1.2mm, Multi Layout , 7u split spacebar, No Per-key RGB, support QMK and VIA )
○ Wired Non-Flex Cut Hotswap PCB
(1.6mm, Multi Layout, 7u split spacebar, No Per-key RGB, support QMK and VIA )
○ Wired Solder PCB
(1.6mm, Non-Flex Cut, Multi Layout, 7u split spacebar, No Per-key RGB, support QMK and VIA )
(Add-on only, 1.6mm, Non-Flex Cut, ANSI Layout, support QMK and VIA )
○ Tri-mode Hotswap PCB
(1.2mm, Non-Flex Cut, ANSI Layout, No Per-key RGB, support Mykeyclub Software)
Noted: The Tri-mode technical support is provided by IRISLab.
○ Plateless
○ Flex Cut Plates: FR4, ALU, Brass (Brass Plate Add-on only)
○ Non-flex Cut Plates: PC, POM
Noted: We highly recommend using a PC/ POM/FR4 plate for Tri-mode PCB
because the Brass and ALU plate will have a little affection for connectivity.
Full CNC Aluminum Top case *1
Full CNC Aluminum Bottom case *1
Weight (Anodized Alu Weight or Stainless steel PVD Weight) *1
Internal Alu Weight *1
PCB *1
Plateless or Plate *1
IXPE Foam *1
Poron Case Foam *1
Poron Plate Foam *1
Type-C Daughterboard with JST Cable *1
PCB GAS Silicone Column *12
Plate GAS Silicone Sock *18
Top mount screw and spacer *12
PCB stabilizers o-ring *12
Footpad *6
Poron case strip *6
1.5mm hex key *1
Gift(will not send make-up or replacements)
1 MKC Stabilizer Set
1 Type-C Cable
1 Pack of Extra Screw
M2x3mm cylindrical head screw *2
M2x8mm cylindrical head screw *2
M3x5mm countersunk screw *2
1000mha battery (Only for the Tri-mode Version Case) *2
Silicone pad of battery compartment *2
Review links (Stay Tuned for More)
Simulator Tech: Black Case+ Gold PVD weight
Rx003: Grey Case+ Black PVD weight
apiarykeyboards: Mint Green Case+ Silver PVD weight
dutchmasterw: Black Case+ Silver PVD weight
바룬 Baroon: Silver Case+ Silver PVD weight
Captain Sterling: Grey Case+ Rose Gold Alu weight
Merkeebs: Black Case+ Chroma PVD weight
Clackbait: Silver Case+ Chroma PVD weight
MechTech Keyboards: E-White Case+ Black PVD weight
Edward Tanujaya: Black Case+ Black PVD weight
kittykat.keys: Wine Red Case+ Gold PVD weight
Zeke DGTL: Milky White Case+ Rose Gold Alu weight
Nicola Sagliano: Wine Red Case+ Black PVD weight
Nextrift: Wine Red Case+ Black PVD weight
MCZ Studio: Milky White Case+ Gold PVD weight
Custom Ton Clavier: E-White Case+ Gold Alu weight
strawberryjam1986: Milky White Case+ Gold PVD weight
Lattech 라떼크: Silver Case+ Chroma PVD weight
Mykeyclub Team
We are a platform that integrates creativity and innovative design, helping more studios join this hobby community and bringing more fun and cool products to you guys. Please participate in our MKC family for more discussions and future updates.
MKC65 IC form
Mykeyclub discord
Mykeyclub Ins
Best Wishes
Mykeyclub Team
