Soarer's Converter IBM Model F XT issues
daniel_j
30 May 2024, 06:06
Hi there,
I have used a pro micro clone to create a Soarer's Converter, confirmed the wiring works correctly with a 5 DIN Model M, however my Model F XT is not working.
I get this output with hid_listen:
Waiting for new device:..
Listening:
wEE
remaining: FFFC
Keyboard ID: 0000
Code Set: 1
Mode: PC/XT
r00 +00
r80 -00
A couple of keys create the r80 -/+00 codes.
Occasionally on plugin I get this:
rFF R05 rAA r3B +3A d3A r76 +73 d73 r3D +3C d3C r00 +00 r3F +3E d3E r41 +40 d40 r43 +42 d42 r00 r3C +3B d3B r00 r3E +3D d3D r00 r40 +3F d3F r42 +41 d41 r44 +43 d43 r38 +E2 dE2 rFF rFF
I've confirmed the cable is fine internally with a multimeter.
Where should I look to next to further debug this?
daniel_j
30 May 2024, 07:47
Got it working, as others say, it's usually a grounding issue. in this case the bolt on the pcb
