DSI smk-85 info
maxrunner
- Main keyboard: custom 60% holypanda
- Main mouse: ergo m570/m575
- Favorite switch: current holy pandas
So i've been searching for small boards with alps/alps type switches, and i found the SMK-85 with white alps. What do you guys thing of this board?
regards,
regards,
- didja
- Main keyboard: AT Model F - 87U - G80-1800
- Main mouse: varies
- Favorite switch: CapactiveBS
Never tried the SMK-85, I think they had strongman switches which were ALPS copies.
My favorite compact ALPS boards that I've tried were Siig minitouch with a switch swap and Ortek MCK-84 with Fukkas.
Ortek MCK-84
Siig Minitouch, White Dampened Swap, Blue Clicky Swap, Blue Monterey original.
Ortek MCK-84
- TexasFlood
- Main keyboard: Rosewill RK-9000 original cherry blue
- Main mouse: Microsoft trackball
- Favorite switch: cherry blue
maxrunner
Hi didja, what does the Ortek MCK-84 use, Fukkas, how are those?didja wrote:Never tried the SMK-85, I think they had strongman switches which were ALPS copies.
Ortek MCK-84
regards,
maxrunner
maxrunner wrote:http://geekhack.org/showwiki.php?title=Island:13826
Seems they released an ISO version....
maxrunner
Is this one the same?
http://epiguru.com/2012/06/for-sale-ort ... s-keycaps/
The user says it uses simplified alps, are those the same as yhe fukkas?
rodtang
- Main keyboard: Old rubberdome
- Main mouse: Logitech Performance MX
It's an ISO (real iso with the key next to left shift) winkeyless version.maxrunner wrote:Is this one the same?
maxrunner
So i just bought this keyboard, and one thing that bothers me is that the numlock key is used to change the keys(u,i,o into 4,5,6...) into the keypad, so every time i turn on the pc i have to turn off the num lock since for default the numlock is always on.
maxrunner
Seems my board bios gives you the option to turn it on or off at boot.
Also, if anyone has this board can they try to activate the scrolLock?
Looking at the color of the text(it shares the same key with delete), it would seem that to activate the scrolL, one would need to turn on the num lock first, but this doesn't seem to be working like that. only by pressing FN and the delete/scrolLock key that the led will turn on.Strange.
regards,
regards,
