upgrade my mousepad
Ramason
19 Nov 2024, 09:41
Hey All,
I’ve been looking to upgrade my setup a bit, and with Black Friday around the corner, I thought it might be a good time to grab something high-quality but budget-friendly. Specifically, I’ve been wanting a mouse pad that can give me really smooth tracking with a durable surface—no more dealing with the fabric pads that start to wear down after heavy use.
I came across the FlashBeyond glass mouse pad (https://www.amazon.com/gp/product/B0DJ8NQC5V?th=1), which seems to have great build quality and a price that doesn’t break the bank. I’ve heard it’s comparable to the Wallhack in terms of smoothness but with a much more competitive price. It’s supposed to be ultra-smooth, which is a huge bonus for me since I like minimal drag when gaming. I haven’t seen a ton of reviews on it yet, so I was wondering if anyone here has tried it out or knows anything more about its long-term performance?
I don’t have a strict budget, but I’d definitely like something that’s going to last without dropping a huge amount. I’d appreciate any recommendations if there’s something better out there for the same price range, or if you think this is a solid buy.
I’m in the US, by the way. Looking forward to hearing your thoughts!
TNT
23 Nov 2024, 15:30
Don't know about this mousepad specifically, but my two cents on glass mousepads in general: Are you are aware that you will have to wear a gaming sleeve whenever using it and will probably also have to upgrade the sliders on your mouse or at least replace them more often? Naked skin will stick to the surface like glue, it's definitely not for everyone. Personally, I'd choose a good cloth mousepad about a glass pad everytime. What kind of pad have you been playing on until now?
