Introduction
Note: this post will be updated. As such it shall be considered work in progress. A change log is shown at the end.
Last change 2025.01.01 (yyyy.mm.dd)
The Sensing PCB is considered priority 1, being 0 the highest priority.
As such, at this stage it is important to record constraints that would affect specifications of other components.
Constraints
- Interface to the controller
- Alignment with the metal plates
Alternatives to be considerer
- Built-in/integrated controlled - impacts the controller and the case. It may increase cost as the controller requires 4 layer PCB while the sensing PCB can used 2
--- change log (yyyy.mm.dd) ---
