[FMF] Free Model F - Solenoid controller
idollar
i$
01 Jan 2025, 03:58
Please refer to the mother GB thread which can be found here
Introduction
Note: this post will be updated. As such it shall be considered work in progress. A change log is shown at the end.
Last change 2025.01.01 (yyyy.mm.dd)
xwhatsit solenoid controller is available and demonstrated to be working in combination with the Leyden Jar, IBM solenoid & COTs solenoids. A FEXT has been integrated with it.
The Solenoid Controller is considered priority 4, being 0 the highest priority.
As such, at this stage it is important to record constraints that would affect specifications of other components.
Constraints
  • Interface to the controller
  • Interface to COTs solenoid
  • Case integration
Alternatives to be considered
  • Built-in/integrated in the controller
--- change log (yyyy.mm.dd) ---
2025.01.01 - initial version
2025.01.01 - updates to align to overall project concept (e.g. priorities, constraints, options added)
