[FMF] Free Model F - Springs
idollar
i$
01 Jan 2025, 04:03
Please refer to the mother GB thread which can be found here
Introduction
Note: this post will be updated. As such it shall be considered work in progress. A change log is shown at the end.
Last change 2025.01.01 (yyyy.mm.dd)
The springs are 0+ considered priority 1, being 0 the highest priority. The "+" implies that the selection shall follow the design of the Capacitive Flippers.
Original Model F springs can be used for testing purposes.
Constraints
  • Interface to the flipper
  • Sourcing
Alternatives to be considered
  • Different type of springs may affect the force required for the flipper to actuate. Investigating options may help to match user's preferences
--- change log (yyyy.mm.dd) ---
2025.01.01 - initial version
2025.01.01 - updates to align to overall project concept (e.g. priorities, constraints, options added)
