[FMF] Free Model F - Barrels
idollar
i$
01 Jan 2025, 04:04
Please refer to the mother GB thread which can be found here
Introduction
Note: this post will be updated. As such it shall be considered work in progress. A change log is shown at the end.
Last change 2025.01.01 (yyyy.mm.dd)
Barrels considered priority 0+, being 0 the highest priority.
They shall be designed and integrated with the flippers and the springs.
Constraints
  • Interface to the barrel plate
Alternatives to be considered
  • Interface to the barrel plate - it should be possible o investigate if modifications improve the integration to the barrel plate, improving the original IBM design. On the negative side this would not allow one to one replacement in original IBM model F
  • Injection vs 3d print - At this stage, I consider that both options shall be investigated and eventually made available for the usre to choose.
--- change log (yyyy.mm.dd) ---
2025.01.01 - initial version
2025.01.01 - updates to align to overall project concept (e.g. priorities, constraints, options added)
