Introduction
Note: this post will be updated. As such it shall be considered work in progress. A change log is shown at the end.
Last change 2025.01.01 (yyyy.mm.dd)
The Foam is considered priority 1, being 0 the highest priority. It shall be designed to work together with the barrel plates.
As such, at this stage it is important to record constraints that would affect specifications of other components.
The initial staring point is the use of neoprene and punch holes. More efficient and automated options may be considered.
Constraints
- Interface metal plate and barrels
Alternatives to be considered
- Mass production
--- change log (yyyy.mm.dd) ---
