[FMF] Free Model F - Stabilizers
idollar
i$
01 Jan 2025, 04:06
Please refer to the mother GB thread which can be found here
Introduction
Note: this post will be updated. As such it shall be considered work in progress. A change log is shown at the end.
Last change 2025.01.01 (yyyy.mm.dd)
The Stabilizers are considered priority 3, being 0 the highest priority.
These metal parts are made bending a rigid metal wire. In case that the original IBM metal bars are used, they can be resed also.
As such, at this stage it is important to record constraints that would affect specifications of other components.
Constraints
  • Interface to the space bar
  • Interface with the metal plates to ensure keycap alignment
Alternatives to be considered
  • none has been identified at this stage
--- change log (yyyy.mm.dd) ---
2025.01.01 - initial version
2025.01.01 - updates to align to overall project concept (e.g. priorities, constraints, options added)
