[FMF] Free Model F - Spacebar Tabs
idollar
i$
01 Jan 2025, 04:07
Please refer to the mother GB thread which can be found here
Introduction
Note: this post will be updated. As such it shall be considered work in progress. A change log is shown at the end.
Last change 2025.01.01 (yyyy.mm.dd)
The spacebar tabs are considered priority 2, being 0 the highest priority. Their design shall be aligned with the metal plates and the space-bar stabilizer.
As such, at this stage it is important to record constraints that would affect specifications of other components.
Constraints
  • Interface to the metal plates
Alternatives to be considered
  • Prototyping with 3D print
  • Solid plastic (inject molding) may be required to avoid breaking under stress
--- change log (yyyy.mm.dd) ---
2025.01.01 - initial version
2025.01.01 - updates to align to overall project concept (e.g. priorities, constraints, options added)
