[FMF] Free Model F - USB cable
idollar
i$
01 Jan 2025, 04:08
Please refer to the mother GB thread which can be found here
Introduction
Note: this post will be updated. As such it shall be considered work in progress. A change log is shown at the end.
Last change 2025.01.01 (yyyy.mm.dd)
The Sensing PCB is considered priority 4, being 0 the highest priority. COTs product.
As such, at this stage it is important to record constraints that would affect specifications of other components.
We shall expect little activity in this post for obvious reasons. It is created for completeness.
Constraints
  • USB C
  • Ensure that different type of cables can be used. This may have an impact on the case design and how the cable exists it.
Alternatives to be considered
  • None identified at this stage
--- change log (yyyy.mm.dd) ---
2025.01.01 - initial version
2025.01.01 - updates to align to overall project concept (e.g. priorities, constraints, options added)
