[FMF] Free Model F - Keycaps
idollar
i$
01 Jan 2025, 04:09
Please refer to the mother GB thread which can be found here
Introduction
Note: this post will be updated. As such it shall be considered work in progress. A change log is shown at the end.
Last change 2025.01.01 (yyyy.mm.dd)
The keycaps are considered priority 4, being 0 the highest priority.
As such, at this stage it is important to record constraints that would affect specifications of other components.
Keycaps can be reused from model m / model f / unicomp keyboards. Thus they are not a priority and let to a later stage.
Constraints
  • interface to the barrels / springs to be maintained
  • Size to be maintained
Alternatives to be considered
  • An option to allow an interface to de facto standard cherry switches to be considered.
  • Regarding the sourcing, IBM boards, unicomp or other keycap manufacturer shall be considered
--- change log (yyyy.mm.dd) ---
2025.01.01 - initial version
2025.01.01 - updates to align to overall project concept (e.g. priorities, constraints, options added)
