Aula F108 Pro with Linux
nelson777
19 Oct 2025, 19:48
Hello all,
I'm thinking in buying an Aula F108 Pro keyboard and I trying to find some info about it and it's use in Linux
1 - I saw that it doesn't have VIA support and the configuration software has Win/Mac/iOS/Android compatibility. I use only Linux. Would I be able to run the configuration software in a Windows VM ? Including configuring the mini-screen ? Has anyone done this ?
2 - As for the mini-screen, I saw only time and keyboard's configurations that I think wouldn't require communication with the OS. So it's more probable that it doesn't have problems with Linux. Is there any communication between the keyboard and the OS in order to provide some function for the mini-screen ? I saw that it shows battery life. Would it have any problem with this in Linux ?
3 - I saw that some Linux users reported that F keys don't work and that they are linked to media function. I also learn that this procedure would work: https://wiki.archlinux.org/title/Apple_ ... o_not_work
Does it ? Is this true ?
4 - Does any Linux user have it and can share more? Any issues in day-to-day use?
Thanks
