Testing a Model F XT with Soarer's Converter
TheBookIsBetter
17 Nov 2025, 16:12
Hello! I recently traded for an untested Model F XT and I'm trying to figure out if it's functional. I've cleaned it up and plan on using it with a tinkerBOY converter, but while I'm waiting for it to get here I ordered a Soarer's converter from Amazon just to test the keyboard. The first time I tried using it, nothing happened. Now, whenever I plug in the Amazon converter into my PC, I get an error balloon saying there's a power surge on the USB port (I've tried multiple ports, with and without the keyboard plugged in to the converter). I think this means the Amazon converter has a short in it, but I'm not going to bother opening it up since I can return it. Does my line of thinking sound right there? Is there any chance the keyboard has been damaged by this potentially faulty converter? Thanks!
smarx
18 Nov 2025, 16:52
can you send a link to this amazon-converter ?
TheBookIsBetter
18 Nov 2025, 16:54
I confirmed the converter was shorted and replaced it, now it's all working great!
