Recommend me a mechanical keyboard for £140 inc p+p or less
- Main keyboard: Cyborg v7 keyboard
- Main mouse: Razer imperator
- Favorite switch: N/A
As the title says i will soon be buying a mechanical keyboard with a price range 0f £80-£140 including p+p so could anyone recommend me some different mechanical keyboards ?
- dirge
If UK layout.
http://www.keyboardco.com/keyboard_deta ... RODUCT=933
or
http://www.keyboardco.com/keyboard_deta ... RODUCT=863
second isn't mechanical and over budget... but have to link it.
or
- Main keyboard: Filco MJ1 Mx Browns
- Main mouse: IE 3.0
- Favorite switch: Mx Browns
Beat me to it dirge
http://www.keyboardco.com/keyboard_deta ... RODUCT=932 damn you!
*but, get the realforce, c'mon, you know you want to
![Razz :P](./images/smilies/icon_razz.gif)
![Wink ;)](./images/smilies/icon_e_wink.gif)
- Charlie_Brown_MX
- Main keyboard: Apple Extended Keyboard
- Favorite switch: ALPS: cream or salmon
No recommendation of a classic Buckling Spring keyboard?
- dirge
A very good point, I think he needs to buy all three.koralatov wrote:No recommendation of a classic Buckling Spring keyboard?
+1dirge wrote:A very good point, I think he needs to buy all three.koralatov wrote:No recommendation of a classic Buckling Spring keyboard?
- Peter
- Main keyboard: Steelseries 6Gv2/G80-1501HAD
- Main mouse: Mx518
- Favorite switch: Cherry Linear and Buckling Spring
+2 !!dirge wrote:A very good point, I think he needs to buy all three.koralatov wrote:No recommendation of a classic Buckling Spring keyboard?
But HEY .. If your budget is 140 Sterling .. Buy whatever you like the most !
The problem in the uk is there's pretty much nowhere to try stuff out... I looked for a while but just got a filco mj1 with mx browns and never looked back...Peter wrote:+2 !!dirge wrote:A very good point, I think he needs to buy all three.koralatov wrote:No recommendation of a classic Buckling Spring keyboard?
- Main keyboard: G80-3000
- Favorite switch: Cherry MX blue
I would suggest that if you get a Cherry MX based keyboard, do not get a UK layout, go for the US (also called ANSI) since it will be much easier if you want to change keycaps. The Keyboard co also stock US layouts. As for actual recommendations, I suggest a Filco with blue switches: http://www.keyboardco.com/keyboard_deta ... RODUCT=835 great keyboard. I'm also very fond of the buckling spring boards (see earlier link).
- Peter
- Main mouse: Mx518
Not just in the UK is that a problem mate ..rhizo wrote: The problem in the uk is there's pretty much nowhere to try stuff out... I looked for a while but just got a filco mj1 with mx browns and never looked back...
'Buy it on the internets and return it if you don't like' seems to be the future .
Maybe there's a DT-member in your area willing to let you try some different boards ?
I would go for a UK-layout board btw,
unless you never look at the board when typing (or you actually NEED US-layout, for coding or something)
it probably WILL annoy you that what you see isn't what you get ..
If you don't look at the board, you might as well go 'blank caps', a lot cheaper in the long run !!
