Poker arrived today.
I can't seem to get the arrow keys in the bottom right corner to function, are they supposed to work with the function key pressed? wasd works as arrow keys with function pressed but not the bottom right ones.
Just got a Poker, got a couple questions
303
- Main keyboard: Das II
- Main mouse: Razer Copperhead
- Favorite switch: Blue's
Aha, great!
I was a little worried, showing it to some coworkers one of them joked about how they need a keyboard that can stand a good slam using it as an example! Knocked one end of the spacebar stabilizer bar out of it's clip. Got that sorted out but was suddenly worried it'd broken something.
That's perfect, I'm so bad at proper shift key usage I practically don't use the right shift so I can just leave those as arrow keys for the most part.
