No joke- Model M with Blue Alps.
486
Prototype board?
I probably would have bought it if it wasn't damaged as the cost or repair would be fairly high. The caps seem to be dye-subbed because you can see a certain amount of wear on them. DS keys wouldn't do that. It odd that it turned yellow. Most M's never turn yellow.
- kps
- Main keyboard: Kinesis contoured
- Main mouse: Kensington Slimblade trackball
Hmm, what's more likely: that IBM made a previously-unknown prototype with ALPS switches and stuck a production Modem M label on it, or that some guy in China stuck a Model M label (real or fake) on a $5 junk keyboard in hope of fleecing some sucker? I'll have to think about that for a long, long time.
- DT Pro Member: 0011
The case is obviously from a IBM Model M, but the innards were probably transplanted into the case.
The label was probably never touched. I suspect that the damage to the case could have been made when the plate and barrels were removed from the IBM keyboard.
- HaaTa
- Master Kiibohd Hunter
- Main mouse: CST L-TracX
- DT Pro Member: 0006
Probably a fake, but Alps did do a lot of keyboards for IBM Japan.
IvanIvanovich
- Favorite switch: MX Red
It's likely some sort of Frankenboard. I also saw some MX pcb shoved into a IBM 5150 keyboard on taobao once... they make some crazy combinations of parts sometimes. I wouldn't put deliberate 'aging' past some either.
486
How could they shove a Alps board into a M Shell. Most, nearly all, blue alps boards I have seen have a flat PCB, not curved. The model M shell is curved. If that is the case, they would of had to do loads of work on the inside.
I suppose will will only find out if someone take a gamble on it. Webwit?
You can see the blue slider under a key cap on the function row. The switches are on a flat plane. There must be something under the key caps, or weird key caps.
- webwit
- Wild Duck
- Main keyboard: Model F62
- DT Pro Member: 0000
Must be a Frankenboard. I'm not touching it.
- hammelgammler
- Vintage
- Main keyboard: IBM Model F Unsaver
- Main mouse: G-Wolves Skoll
- Favorite switch: Buckling Spring (Model F)
Wow that's a weird board, but nevertheless kind of cool. I would really like to own something like that.
- seebart
- Offtopicthority Instigator
- Main keyboard: Rotation
- DT Pro Member: 0061
I thought I'd seen it all... :O
- photekq
- Cherry Picker
uwot
- hammelgammler
- Vintage
Aren't those caps yellowed?
I assume IBM went Alps at some point for the same reason they went Oak earlier on. Some hocus-pocus about electromagnetic emissions or the like.
http://deskthority.net/wiki/Oak_Full-Travel_Membrane
terrycherry
- Main keyboard: Model M, dodoo dome keyboard,CherryMX numeric pad
- Main mouse: logitech Master,M705 and 3 Logitech mice
- Favorite switch: ff
I saw it month ago whether it worth.
Who brought it?
Who brought it?
- hammelgammler
- Vintage
Me. I will post pictures when it arrives.
terrycherry
Great. Take more picture and clearly please.
I'm wondering that SDL port was original linked to the PCB.
- photekq
- Cherry Picker
