I got my first Model M (an SSK from '87, which makes me feel a bit lucky) last thursday, and I've been wondering a few things:
Both shift keys are harder to press on one side (namely on the switch side and not the stabilizer side, if you know what I mean). Is this normal? Depressing it with a lot of force makes it go down and feel better for a while, but after some time it's hard to depress yet again. Actually, the right Shift key got stuck at first when I got the keyboard, but I managed to fix this by cleaning the switch and stabilizer parts, or rather removing dust from them, with a cotton stick thing (seriously my English skills aren't sufficient for these - I have no idea what they are called really
The other problem I have is the right Ctrl key, which I found extremely hard to depress. I don't know how (and whether it's common or not), but the spring in this switch had managed to jump off the stem (pivot plate thing?) and gotten stuck between the keyboard's case and "plate". Therefore, I pulled it out, and managed to stretch the spring while doing so, since it had gotten stuck rather hard. The problem now is I can't seem to get it to stick to the stem where it should be, which makes the Ctrl key either hard to depress or to not work at all. What am I supposed to do with this? Is my only solution to buy a spring from Unicomp for $.20 and pay $20 shipping?
I hope my self made buckling spring terminology (and way of writing just before going to sleep) doesn't confuse too much!
Otherwise, I must say I'm extremely happy with the keyboard. I thought it would be nice, but I still got surprised by how nice it actually was. And when the keyboard itself only was like $55, it just feels even nicer.
Thanks for reading.
