On ebay I won this wonderful olivetti keyboard
An ANK 25-102...but it doesn't work on winxp...it has serial port but doesn't power on on post...it needs some trick to work on winxp? An adapter? Thank you for you support...
Not always....I recommend you get in touch with Grond, hes italian and has a small collection of Olivetti boards, he should be able to help you.rodtang wrote:If I remember correctly, dyesub and some not very good switches.Daniel Beardsmore wrote:At least tell us what the switches are, and whether the caps are double shot
Yep you're right...I'm not an keyboard expert, but I can feel that the touch is not mechanic...I'm looking for a mechanic model M...next week I'll let you know about it...pasph wrote:All the ANKs are rubber dome but really good, i think the 102 was sold with M24
Hi!ledpoisoning wrote: 06 Nov 2012, 13:13 Great updates guys!!
I simply connected a PS2 male to original port with this diagram:
PS2 male:
1: DATA (PIN 1 from serial port to PIN 1 PS2 male)
2: NC
3: GND (PIN 3 from serial port to PIN 3 PS2 male)
4: VCC (PIN 9 from serial port to PIN 4 PS2 male)
5: CLK (PIN 2 from serial port to PIN 5 PS2 male)
6: NC
There's only a wire, PIN 4 of serial port that I hadn't connected...
Now it's working great...there's only a few second of delay at the push of Bloc num, bloc scorr and caps lock, it works immediately but led power on after 4 or 5 second later...I don't know why!
Thank you for the info, maybe this solved problem can will be helpful to somebody in the future, older keyboards has a special charm!!!![]()
