I've been using space as modifier at work to have arrow keys like on the KBT Pure and found that surprisingly convenient to use.
Soo.. I'm thinking of building a custom keyboard. I don't have the time nor money for a custom PCB so I'm going to use an ISO G80-3000 PCB, cut it down to 60%, modify the layout to ANSI and add the split spacebar.
I'll get a teensy and will try to make my first own keyboard
Both "spacebars" will work as space and the green Alt key will either be dead (ust as fn key) or maybe a windows key.
I want to keep the physical changes to a minimum for now.
The green key is meant to be pressed once and the next keypress within the number row will return the corresponding function key scancode because I think its kinda uncomfortable to keep it pressed while pushing Alt+F4 or Ctrl+F11.
I don't have enough stabilizers yet and I'm not sure how to mount the switches as I'll have to drill some new holes where already are holes.
Does anyone have some tips as for the mounting of the switches and where to get stabilizers?
Oh and has anyone by chance build anything similar to this yet?
